Amp suggestions??
Username: Arwlacrosse182
Post Number: 16
I have two alpine type r 12" subs and they are 500 watt rms and 1000 watt peak. i would like a not to expensive amp but is still a good amp that will get them lound. looking on spending 200-300$ dual voice coil and 4 ohms
Username: James1115
Use a simple...
Post Number: 8716
orion Hcca 250g4, it does 1000watts @ 1ohm. I have one in excellent condition for you if you are interested.
Username: Rob932
Post Number: 99
I got a precision power pcx1500 that does 1000watts @ 2ohm in good condition if your interested.
Username: Rob932
Post Number: 100
I have a precision power pcx1500 that does 1000watts @ 2ohm in good condition if your interested.
Post Number: 19
how much
Username: James1115
Use a simple...
Post Number: 8721
for which one?
Username: James1115
Use a simple...
Post Number: 8722
I want 250 shipped
Post Number: 20
will it power both of them?
Username: James1115
Use a simple...
Post Number: 8726
yes with ease
Username: Rob932
Post Number: 101
$250 shipped for the pcx1500
Username: Van_man
Boston South, MA
Post Number: 1709
Memphis 16-ST1000D $225 Shipped
Power ratings for this amp are listed as
300 watts into 4 ohms,
600 watts into 2 ohms,
1100 watts into 1 Ohm.
Output Power 4 ohms
533 watts @ 14 volts;
482 watts @ 12.8 volts;
Output Power 2 ohms
791 watts @ 14 volts;
643 watts @ 12.8 volts;
Output Power 1 ohm
997 watts @ 14 volts;
886 watts @ 12.8 volts;
246 watts @ 10.5 volts;
Username: Loc_out
Santa Ana, Ca
Post Number: 605
I'd say buy James amp. Most likely your car wont be putting 14volts. At 12.8 is only 886. But that's just me.
Username: Qbenjamin
Florida
Post Number: 189
Depeniding on you car, but you should get at least 13.8...14.4 takes some minor upgrades like a Yellow top and a Distributor Cap. The PCX from James would be nice, but Memphis is better quality and they give you specific ratings at specific voltage readings. See if you can find the ratings for the PCX and look it up in comparison to the Memphis amp. Volt for volt, there is no contest, MEMPHIS is better.
Username: Qbenjamin
Florida
Post Number: 190
Woops, my badd James, I got you and Robbie mixed up. You won't see much of a power difference between the Orion and the Memphis amp, both of the two would be great options.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3867
All those amps are good!!
