Component Vs. Full Range
Username: Qbenjamin
Florida
Post Number: 188
I am looking to replace my stock 6'9's, but I can't decide which of the following to get. I am goin to get the PG-X100.4. I can make a custom fit for something as small as a 5-1/4, but no larger than a 6'9
Please comment on the following:
CADENCE CWM6-KIT ALUMINUM ALLOY 6.5" COMPONENT KIT - RMS 100W Sensitivity: 93dB @ 1w/1m SPL Frequency Response: 65Hz - 22KHz
POLK AUDIO MOMO MMC6500 6-1/2 COMPONENT SPEAKERS SYSTEM - RMS 125w Sensitivity: 90 dB Frequency Response: 43-25,000 Hz
PHOENIX GOLD X5.0 Xenon 5-1/4 Component System 5.25 - RMS 150w Sensitivity: 86.8 dB Frequency Response: 60 Hz - 22 khz
ROCKFORD FOSGATE T1693C 6X9" 3-WAY SPEAKER SET - RMS 110w Sensitivity: 90 dB Frequency response: 40-22000 Hz
The crossover they will be hooked up to is:
Memphis -16-XO3
All input is appreciated, THANX.
Username: Extrmndor3
Sit and Look pretty
Post Number: 3186
the xenon are your best choice they sound simply amazing too bad u can only find 5.25 and i need 6.5 thats why i got the regular octanes but the z rated they sound amazing
