with that amp, eitehr will work, but I'd recommend you use four of the 4+4 ohm DVC models in a series-parallel configuration you'll get 2 ohms at the amp 300w per sub
thnaks glass what do u think i should do about this...i have a jimmy my box can only have a width of 38 inches and i cant find one for 4 12's anywhere on the net...do u think i shoud just make my own?? i pry could do it but i dont know how well it will be...
ive seen a box for 4 12's on ebay. dont remember the dimensions nor the price, but if you keep an eye out you can find it. it ahs 2 cut outs on a front piece, then 2 subs on the sides that are angled to the side(to save sace). each sub has its own chamber as well. but if you or someone you know has experience in wood working, you would be much better off making a custom enclosure.
