Hooking up my speakers to my amp, and mixing subwoofers.
Username: Korpseofdeath
San Lorenzo, California United States
Post Number: 36
Ok, I have the JBL GT 1201.1 II amp. It can be wired into 4ohms, or 2ohms stable. Now It has two speaker terminals, like a 2ch amp would, and the instructions said its for easier hook up for multiple subwoofers. So I have 2 4ohms SVC and I want to hook down into 2ohms, but since the amp has 2 inputs, if I put each subwoofer on there own input, is it going to down it to 2 automaticly? or what. Kinda get what i'm sayin, its kinda hard. I will post a pic if you need help. My last question, is is there a problem with mixing a 10" woofer and a 12" woofer, both 4ohms SVC, and could be wired down to 2ohms. Would that work or just mess things up? Let me know.
Username: Adddisorder
West palm, Florida
Post Number: 2635
yes dont mix subs or sizes. it will result in cancellation and sound bad
Username: N2audio
Lawrence, Ks USA
Post Number: 1110
"if I put each subwoofer on there own input, is it going to down it to 2 automaticly?"
Yes, the speaker outputs are parallel inside the amp. Therefore, whatever you hook to one +/- is parallel to the other.
Mixing sizes and/or brands and/or models is never advised, but if you try it and you're satisfied then I guess that's all that matters.
