Worried
Username: Zoomiebird
Gville, FL
Post Number: 212
Well i was doing a little research into this FMOD thing, since my amp doesn't have a subsonic filter (jbl bp1200.1). My Q is in the mail, and i plan on installing it in a ported box tuned to 32.4hz. Scott from Fi had some worry that if i played anything that went below 32.4hz my sub would be playing in open air. After googling FMOD i have a headache and doubts about it being the solution to my problem. If FMODs are the way to go which ones should i get? Or, is there a better way, other than sealing the box, to protect my Q from over excursion?
Gville, FL
Post Number: 213
bump... has no one delt with these?
Gville, FL
Post Number: 215
anyone? anybody? no one... polo, chad, muddy, other gods of car audio, please have mercy on me, and tell me WTF to do!!!
Username: Adddisorder
West palm, Florida
Post Number: 2481
partsexpress.com i belive sells subsonic filters.
Username: Basshead86
FTW
Post Number: 9609
don't worry dude, be happy.
tune the box lower. or use common sense when listening to music with low bass.
problem solved:-)
Username: Cenus
Hicksville, Ohio
Post Number: 2713
its useally safe to run a sub 5-7hz below box tuneing, i really wouldn't worry about it. since "most" music doesn't go below 30hz.
Gville, FL
Post Number: 223
thanks dudes. i ordered fmods yesterday, just to be safe.
