Wanted-Used Epicenter
Username: Dsmith07
LaGrange, NC US oF A
Post Number: 374
whats a reasonable price for a used epicenter
Username: 54danny54
KY More Wang Th...
Post Number: 3067
about 100 dollars is reasonable id say.
there like 150 new if im not mistaken
Fi AudioBTL
Post Number: 8226
i am willing to sell mine for 60 shipped.
one problem though. it works perfectly but the problem is the power is constantly on. it doesn't drain alot of battery so you don't have to worry.
Username: 54danny54
KY More Wang Th...
Post Number: 3068
lord 60 shipped.
thats a deal
Username: Adddisorder
West palm, Florida
Post Number: 2490
damn chad what do you think is the problem with it???
Fi AudioBTL
Post Number: 8234
i don't know. i bought it used from ebay and it was like that. it works fine though. its just when i shut off my car, the power light stays on.
i didn't want to bother with opening it up and trying to fix it.
the reason i am thinking about selling it is cause i want everything to be perfect. lol. i am in no hurry to sell it though.
Fi AudioBTL
Post Number: 8237
bump
Username: Extrmndor3
Im pushing i... And pushing ...
Post Number: 2975
hey chad lee i might geet it :-) can u wait alil ?? cuz im buying more subs but im definately gettin that epicenter if ur willing to sell it thanks man and tell me twat u think
Fi AudioBTL
Post Number: 8240
hit me up sometime in mid january. i don't feel like changing out right now.
Username: Th3pwn3r
Chicago, Illinois U.S.A
Post Number: 833
Chad run a toggle switch to that bad boy and be done with it :-) That's what I would do anyhow.
Fi AudioBTL
Post Number: 8248
i thought about that but everytime i turn on my stereo i have to flip the switch. too much work for me.
Username: Tremor1127
Post Number: 601
way too much work...
Username: B101
DD, RE, FI, TREO, KICKERUSA
Post Number: 4086
why not hook both power wires to your remote wire?? should cure the problem.
Username: James1115
Use a simple...
Post Number: 8338
thats what I was going to say B:-) or Rob's idea on a toggle you lazy korean punk:-)
Username: B101
Post Number: 4090
yea, cause its less than 5amp draw. even if both remote and pwr is shorted internally, they both can just hook to a remote wire. the epicenter doesnt need memory or anything.
the toggle idea is good, but u can have to many toggles!
Username: James1115
Use a simple...
Post Number: 8346
I would reroute the remote to the fusebox not to your headunit that way if it ever does draw to much it will blow a fuse in your fuse box not your Head unit.
Fi AudioBTL
Post Number: 8263
well i do have a relay james.
Username: Th3pwn3r
Post Number: 837
Well then stfu! :-) Just kidding Chad how about you use telekinesis and umm disconnect and reconnect the wire that way,since you're so fuggin awesome and all!Hows that new box coming along?
Fi AudioBTL
Post Number: 8266
well the new box is coming along just fine. i am gonna be done with the install by monday afternoon. i will be hitting hard again.
i think i will just leave the epicenter alone for now. like B said, its only a 5 amp draw when the music is on so when the music is off its alot less than that. i do have 2 batteries so my battery isn't gonna go dead.
Username: Th3pwn3r
Post Number: 840
Hey...5 amps is 5 amps. :-)
