Like
A little opinion plz?
Username: Highstone
Post Number: 342
hi guys has anyone heard of this subwoofer?
http://www.target.com/gp/detail.html/sr=1-1/qid=1166571645/ref=sr_1_1/602-578764 1-4008628?ie=UTF8&asin=B000JCIGDW
is it any good?
for a beginner?
thanks
Username: Bernymac
Cambodian
Post Number: 1389
for that amount of money you can get a 12" type R or some Assassins. If your going to do something, do it right the first time. why waste your money.
Username: Nyyfan13
Fi SSD USA
Post Number: 1737
thats funny, someone else on here is looking at fusion subs. i personnally havent ever heard of them before that first kid so i couldnt tell yuo if they are good or not. i beleive i heard someone say they are decent.
Username: Andrew571
Post Number: 455
even if you are a beginner, it doesnt mean you cant buy something decent or even good...
give a budget and ideas of what exactly you want (loudness or sound quality) and the people here @ ecoustics will hook you up bro!
Username: Nyyfan13
Fi SSD USA
Post Number: 1738
but yea id get something else personnaly
Username: Highstone
Post Number: 343
ok lets say if i can get this for 30 bucks is it worth it?
Username: Highstone
Post Number: 344
my budget is very low.. it's 50 bucks including the box... (yes i told u..) and i got 300 watts RMS to give...
Username: Andrew571
Post Number: 456
its not worth it, but if ur set on it - then no1 here is stopping you
Username: Highstone
Post Number: 345
alright..
thanks for ur input... so u got sumthin for me ..
50 bucks including box....
Username: Highstone
Post Number: 346
hellooooooooo?????
Username: Zoomiebird
Gville, FL
Post Number: 202
build a sealed box yourself, then find an old sub on ebay. others here would now the older good stuff better than i.
Nj US
Post Number: 2173
Funny. Once I saw Target in the link above, I knew it had to be a gas.
***Rule #1*** Never buy car audio where you can also buy picture frames, diapers, and dog food.
Username: Fatkid
Post Number: 52
i have a 12" version of that sub hooked to a 500 watt max amp and it sound good in my car. it gets to 125 db. after awhile it starts to hurt. in the right box and right amp it will sound good. i like the fusion subs .
Nj US
Post Number: 2174
Target is an awesome store. Cleaner than Walmart, closer to me than anything else, and I like red better than blue anyways.
Seriously. You really can get ok subs in some places. Entry level by definition, and affordable. No doubt someday you'll be shopping in those same stores you bought those subs in and think: "Those were the days".....but you wouldn't do it again.
Trust me.
Username: Tanmanfosho
C Bang, Hardcore Iowa USA
Post Number: 211
i agree with with paul :-D. but if u only have 50 bucks definetly check ebay or even better save up
Username: Oglejust
RE SX, USA, Il
Post Number: 534
just save up dude... trust me i know from experience
Facebook
Shop Related Deals
Directory
