Coolant Fan
Username: Camarobump
Post Number: 59
My amp keeps going in protection after turning the volume up for a while. What would be a good coolant fan to put back there that isnt expensive? thanks for all comments
Username: Carguy
Post Number: 5814
What brand/model of amp do you have? If your amp is going into protection often, it's most likely caused by low speaker/sub ohms. Make sure you don't exceed the minimum requirement. If all that's fine, then invest in a good cpu fan. It should work right off the amp. Match the voltage of the fan. Some are 5v, while others are 12v.
