Clifford Valet Code / Switch
Username: Leon1979
Manchester
I think I know the answer to this, but thought I'd best try and check.
I've got a concept 600 and need to stick the alarm into valet mode via the switch and code. I know I have to enter my code by entering numbers 1 to 9 with 1 button and press the other after each number.
But which button is which???????
I thought the plain button was the 1 to enter numbers and the * button the one to use as enter. Am I right?
Also, do you have to hold the * button down at all after the full valet code has been entered????
