For those of you who resined their box
Fi AudioBTL
Post Number: 8109
how did you resin the last side of your box? what i mean is when you leave one side open, you can reach all parts of the box but when you close the box, how did you resin the last piece?
Username: James1115
Use a simple...
Post Number: 8192
go in through the bacl and do the whole thing, then put the back on and go in through the speaker hole in the front and do the back:-)
Username: Drivingreckless
DD 9515f, USA
Post Number: 2554
the way i do it chad
since i have a 15" sub i can fit threw the sub cutoutt and i resined the opposite end of the sub cutout
so all u have to do is reach ur hand threw and not have to torque ur body
Fi AudioBTL
Post Number: 8112
that is going to be a problem james. i decided to put the top (where the sub cut out is) last so i already glued all the other sides. it looks like a big bath tub right now.
Username: James1115
Use a simple...
Post Number: 8193
ohhh man that sucks
Fi AudioBTL
Post Number: 8113
hey don't just say that. think of something james. i don't need your pity. i need your ideas!!!!!
rofl.
Username: Adddisorder
West palm, Florida
Post Number: 2385
hahaha your screwed chad, just kidding man, try glassing the front panel while its off and then screw it on to the box, then reach inside the box threw the sub cutout and resin the edges. it wont be easy but it should work.
Fi AudioBTL
Post Number: 8118
thanks mat. i think that is the best way. should i leave the edges resinless so it will have a wood on wood contact?
Username: Rovin
1 12 Premier...
Post Number: 10150
i heard of ppl actually using a few coats of oil based paint\varnish inside their box & they say its a cheap ghetto way instead of resin
hmmm- does that work ?..........
West palm, Florida
Post Number: 2400
i dont really know chad. i guess if its easy enough, have it so its wood on wood, then when you got the top on the box and your going inside it putting resin in to join it to the rest of the box it will cover whatever you missed.
if you resin the whole lid it might be slightly uneven where as wood on wood is perfectly flat.
Username: Van_man
Boston South, MA
Post Number: 1478
mix it up loose, then pour it in the port or where ever and just turn the box so the resin flows where you want it to go. Use less hardner so it wont set up as fast and give you time to turn the box for an even coating inside.
Username: Safe_cracker
Chicago, IL US
Post Number: 2192
What is so hard about it? I resin boxes completely assembled to seal the whole inside. If you need to reach inside the port use a foam roller they come all sorts of sizes. Honestly, it isn't worth all the trouble to resin the inside of the box as for MDF is smooth enough. More of a difference can be seen in rounding corners and making sure the panels won't resonate excessively. Polo..
Username: Bernymac
Cambodian
Post Number: 1371
Chad, your building your wall already?
Fi AudioBTL
Post Number: 8128
no its just a box and yes i started already. i should finish by the christmas weekend.
Username: Bernymac
Cambodian
Post Number: 1383
oh ic, just a box heh. I wonder. Yeah man, if I don't get lazy this coming wenesday,thursday and friday I could finish up my setup. I mean, wenesday I do edead, wenesday I reinstall everything and hook up my wires, and then by friday I finish w/e. I need to start bangin again, I've been bangless for a few days now, its whack.
Chicago, IL US
Post Number: 2195
Berny, that is why you need a backup system! Here is mine, the only way I would run 10's. Notice the two strapped Kicker SX1250's at the top edge of the box, these SSI's really take the punishment! Polo..:-O
Chicago, IL US
Post Number: 2196
Chicago, IL US
Post Number: 2198
B
U
M
P
W
T
F
:-O
Username: Andrew571
Post Number: 460
i have a question about resin (i never resined b4 ) ...when u resin the port...do u spray paint it black on the wood first...or will the resin hold the black spray paint?
Username: Bernymac
Cambodian
Post Number: 1395
its all good. I rather go without any bump. That way, when I do put the new system in, I'll be extraordinarily happy :D.
Username: Johnfiac
IL USA
Post Number: 774
i smoked enough pot in my ride to resin the inside of my ride and had no problem doing it...comon chad u can resin a box!!! lol
http://www.youtube.com/watch?v=AyPpO4DvuzU i finnaly made a video :p for pos subs they take a hell of a beating.. i also had the bass most the way down on accident LMAO
Fi AudioBTL
Post Number: 8151
andrizzle i believe the resin will hold the paint.
nice vid killa. some good sh!t.
Username: Johnfiac
IL USA
Post Number: 786
thanks
im making a new one later today with the subwoofer level on the HU set from 0 to 6 (what i actually had it on when setting my gain) completely forgot about it being so low after leaving work... downtown chicago cops like to be di<ks if ur wanging ur sh!t at 9am lmao
