Setting clock on Pioneer DEH-16
Username: Marcocruz69
Hidalgo, Tx US
Could you please help me to set the clock on a Pioneer DEH-16, I haven't been able to find the manual.
Username: Jaackdeth
United States
Post Number: 713
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/33399012operati on%20manual%20deh-1600.pdf
Username: Tuzz
Press SOURCE and hold until unit turns off. Press AUDIO and hold until clock appears in display. Press <or> to select the segment of the clock display you wish to set (hour or minute). Press ^ to increase selected hour or minute or down to decrease hour or minute.
Hidalgo, Tx US
Thanks for your help Jack and Jimmy, my problem now is solved.
Again thank you so much
Username: Jaackdeth
United States
Post Number: 719
NP, good luck.
