Help!!!!
Username: Jmh2004
P. A., Texas
Post Number: 66
Someone please help i bought the a8002v amp in june i had everything set up right and it just went out everything it was connected right and will not power on i checked the fuses it doesnt smell burnt or anything and even connected it direct to the battery (remote as well) to test it still does not work... please help... i cant be without bass too long... thanks
Username: James1115
Use a simple...
Post Number: 8139
sounds like you blew a power supply. Audiocrap is known for it. take it apart to see if you see anything melted or black, or unsoldered.
Username: Van_man
Boston South, MA
Post Number: 1466
Re check your ground.
If you jumped rem and power to bat and didnt come on, check the ground. If it is good then amp is bad.
Username: Miho1379
Austin, Texas United states
Post Number: 7
i would say take the REM off the direct path to the battery and connect it to the PWR wire on back of your deck its probably red, make sure you can see your ground connected straight to the chasis of your car, and then try it...if still nothing then i would def. say its a blown amp
hope that helps!
Username: Jmh2004
P. A., Texas
Post Number: 67
it was the main fuse i check it first and everything looked normal but i did a power test on the main power cable and i found the main fuse is not working i replaced it and its all good now.... thanks for the help
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3743
well... the comment from jlongo hehe kinda harsh! but it's true
