What amp should i get?
Username: Camarobump
Post Number: 56
What amp should i purchase for 2 DA9012 subs? They are 1100w rms a piece.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3722
voice coil config please
Post Number: 57
dual 4 ohms, or 2ohms and 8ohms operation
Username: Sinful_systems70
Post Number: 174
Just so you know (2)dual 4 ohm subs wire to 1 or 4 ohms if you plan to run the two subs with one amp.
Username: Kelldd
Vancouver, B.C Canada
im new here ..... how do u make your own post eny one hellp me ...
Username: Juliob
Post Number: 3741
if they're really 1100w rms a piece you need a 2000-2200w rms amp at 1 ohm
Tell us a budget to work with
