Trying to set my gain!!! help
Username: Oglejust
RE SX, USA, Il
Post Number: 495
ok im trying to set my gains and its not working out.. i put in a 50hz test tone then went to set my gains and i cant get my target voltage of 37.4volts. if i turn my bass boost on i can get it but ive heard not to do that. will i be alright to turn my bass boost up so i can get my target voltage?
Username: Ctmike
Ct.
Post Number: 2669
what do you mean you can't get to 37? like you're turning the gain and you reach the highest it gets before reaching 37?
Username: Oglejust
RE SX, USA, Il
Post Number: 496
correct... the gain can b all the way up and it still wont go to 37.4 it only goes to like 20
Username: Ctmike
Ct.
Post Number: 2670
what ohm load is it? you have a kx1200.1 right?
Username: Oglejust
RE SX, USA, Il
Post Number: 497
no i have an ed nine 1 and its at 1 ohm
Username: Oglejust
RE SX, USA, Il
Post Number: 498
bump
Fi AudioBTL
Post Number: 7837
you have your volume set at 3/4 i hope.
Username: Oglejust
RE SX, USA, Il
Post Number: 499
ya i do
Username: Frkkevin
Post Number: 2132
he does.. i told him how to set the gain :-) ... i was boggled when that amp only put out like 20volts with the gain all the way up..
now you should not have to use bassboost to increase voltage.. if so that amp is really wack. only thing i can think is maybe the amps input voltage is too high for your h/u preouts .. not sensative enough for low voltage. a linedriver would fix that but you said you don't have money so...
