Battery help
Username: Holt_champ
Htown, MI
Post Number: 473
ok i havent been around and forgot what ppl told me. i have a 200 amp alt. i am going to run a kx2500.1 so how many batteries would i need. i can only fit a kinetik hc1400 under the hood. would i need more bats in the back or would i be set with just the one.
Username: Adddisorder
West palm, Florida
Post Number: 2836
probly the 1400 in the front and maybe an 800 in the back
Htown, MI
Post Number: 476
would i need more than that do you think??
Username: Carguy
Post Number: 5841
If you don't listen with your car turned off, then you don't need 2nd battery. 200A alternator is more than enough.
If you want 100% safety, then install an isolator and 2nd battery. That way your starter will never be drained by the amp.
Htown, MI
Post Number: 477
so with a 200 amp alt and a kinetik hc1400 i should be good?
