Like
Anyone want to see.....
Fi AudioBTL
Post Number: 7710
anyone want to see a video of me plugging one of my btl to a wall socket?
Username: Frkkevin
Post Number: 2076
you would not do it :-)
Username: Tdawg30
Ohio USA
Post Number: 729
dont do that man. send it to me so I can enjoy the actual use of it. please
Username: Devastation101
Audioque SD2.5-ville, HENDERSON, NC US of A
Post Number: 454
I don't wanna see it if it's gonna HURT the sub...but if it isn't gonna hurt, WHY NOT! lol
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 10692
do it...why not?? how much is a recone??
Fi AudioBTL
Post Number: 7713
rofl. i am so tempted to do it. but i am afraid it will mess up. its not the money. its the waiting.
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 1233
Sure, but first see what it does on the TL in a box, then what it does on the TL frying it.
Fi AudioBTL
Post Number: 7715
well the wall socket is 110v and i've had my amps to put out 110v and the sub was fine. maybe its different if its real electricity.
Username: Troy81
Tavernier, Fl Us
Post Number: 1415
wire it to 8 ohms and its only like 1900 watts at 60hz, itll be fine
Username: Rovin
Trinidad & T...
Post Number: 10076
let scot of fi read this & i guaranty he will void ur warranty asap .......
Fi AudioBTL
Post Number: 7717
well there is no warranty on the btls rovin. after all this sub is called built to last. lol.
Username: Tremor1127
Post Number: 552
i bet 20 bucks right now, and you will get my money, that it will last with no more than a smell after 30 seconds...
Post Number: 553
bet...
Username: Extrmndor3
Im pushing i... And pushing ...
Post Number: 2836
yeah plug that so we can compare to the apx and see if it has some guts but by the way the apx was plugged at a 220 volts outled and took it like a champ and the coil looked like new :-) it was around 26000 rms close to 30k rms watts at like 60 hz
Username: Redliner
Wilmington, Ma
Post Number: 3361
the prob is chad not the amperage its the fcat it wont be dc anymore like in a car it will be ac. which dc is continuous and ac is little pulses which the frequency is 60 in the us so it will be getting 60 pulses every second thats what messes it up.
Fi AudioBTL
Post Number: 7721
come one now rob. you can't compare this sub to that monster apx. give me a break. but 110v i know it can take.
isn't the apx suppose to handle like 30,000 wrms for short burps?
when it comes to power, rob is right when he talks about the apx. they are just about the toughest they can be.
Post Number: 2837
i know but i think the btl will handle that power im sure the btl will take up to 10 k at burps so yeah wire it at 8 ohm and ull be fine :-)
Username: Troy81
Tavernier, Fl Us
Post Number: 1417
charlie wth r u talking about that was an entirely false statement, a sub in a car is getting AC current, you have 3300 posts, you have to have been here at least as long as i was, please, pretend like you know what your talking about
Username: Mr_kebo
Albertville, Al USA
Post Number: 880
its getting DC in the car not AC
Username: Troy81
Tavernier, Fl Us
Post Number: 1419
oh is it? try again, damn man whats goin on around here
Fi AudioBTL
Post Number: 7725
mr kebo the amp takes dc and converts it to ac when it sends it to the subs. that is why when you set the gain with dmm, you set your dmm to ac volts.
i realized that 110v would be around 12,000 wrms at 1 ohm. i think my sub can take it. the question is what frequency will that be?
Post Number: 2838
amp will turn dc to ac :-)
Username: Troy81
Tavernier, Fl Us
Post Number: 1422
60hz btw, :-) and thank you for clearing that up for him i guess no one believes me
Username: Troy81
Tavernier, Fl Us
Post Number: 1423
and if you wire it at 8 ohms its only 1500 rms, maybe a bit more
Fi AudioBTL
Post Number: 7728
60hz. thats pretty good. my car peaks at 51hz. i should get a tl and meter it while the sub is plugged in to the wall.
how about i get a strong power inverter in my car and just plug the sub to that. you think i will get full 110v out of the inverter?
Fi AudioBTL
Post Number: 7729
the problem i have doing that troy is my sub is dual 2 ohm. i would have to use both of my subs to get 8 ohms.
Username: Troy81
Tavernier, Fl Us
Post Number: 1424
nope, itll blow a fuse, it makes 110v but only like 50 amps while a house socket would make lets say 150 amps... im not sure on the numbers im just putting it in perspective
Fi AudioBTL
Post Number: 7730
yeah it was a wild stab at a stupid idea i had. lol.
Username: Troy81
Tavernier, Fl Us
Post Number: 1425
well wire at 1 ohm and make some boom, or if you want to garentee not hurting the sub wire @ 4 or use both subs........ if you wire @ 4 it will be ust like wiring both subs at 4, just the wall will see a diff ohm load
Fi AudioBTL
Post Number: 7732
when i get the box done i might just try it. lol.
i wouldn't do it free air.
Username: Safe_cracker
Chicago, IL US
Post Number: 2127
I used the voltage target calc to figure out what 220V would be equal to in a 1 ohm load and it said the amplifier would be 48410 rms, lol. Polo.
Fi AudioBTL
Post Number: 7734
damn how many batteries and runs of 0 gauge do you think you need to support such an amp. damn.
Username: Basshead86
FTW
Post Number: 9408
i don't see you having a problem with it wired to 1 ohm for 30 seconds. those things are REDICULOUS....
Username: Adddisorder
West palm, Florida
Post Number: 2200
x2 it should take it fine. iv seen dd9500s on wall sockets free air and they took a long time to blow
Username: Andrew571
Post Number: 355
i wanna see itttttttttt when u even gunna be done with ur box chad
Fi AudioBTL
Post Number: 7742
actually i am not afraid for my sub. what if i blow a fuse in my house. i might cause a black out.
Username: James1115
Use a simple...
Post Number: 7754
thats why there is a breaker panel:-) DO IT!!!:-):-) atleast send it to me first to run for a while before you blow it:-)
Username: Ccdoggy
Post Number: 80
What will happen is you're going to blow a fuse. the standard wall outlets are only rated for a max of ~25-30 amps. which =~22500watts
If you are going to try it you need a load that will give you about 1500 watts, as depending on if you're house is new or old there could be problems going above that. Like a house fire at worst, at best just a blown fuse. The wires in the wall could heat up adn start a fire.
Dont get me wrong, i would love to see a vid of it. But be careful as i dont wanna see you're house burn down because of it.
Username: Adam_s
Sound Splinter, RL-p 15 D4 2.7 Cuft @ 3...
Post Number: 396
IT wont burn down the house or nething....its the same thing if you have too many things going at one time like a toaster, foreman grill, and microwave....it will pop the breaker once it reaches the most current....15-25 amps in most houses....not sure exactly what yours is.
Username: Denali_on_22s
Maryville, TN Us
Post Number: 649
Haha.... I don't know why, but I found this thread to be curiously funny.
Facebook
Shop Related Deals
Directory
