Holy hell!?!?!? what to do?
Username: Zoomiebird
Gville, FL
Post Number: 142
here is part of a letter from scott at Fi:
Thanks for the inquiry. The only issue I really see with your setup is with
the amp. The 1200.1 doesnt have a subsonic filter, which becomes an issue
when using ported enclosures. Being tuned to 32, will mean that anything
below 32 Hz, the port will act as a "hole" in the enclosure and allow the
sub to unload as if in free air. Definitely not a good thing to do to a
sub. So you will need to watch things carefully when selecting music to
play at high volume levels to avoid over excursion of the Q. This goes for
any sub in a ported enclosure using an amp without a subsonic filter.
Other than that, a Q15 D1 (dual 1 Ohm wired in series for a single 2 Ohm
load for your amp) will work great.
WHAT TO DO???? is there any fix to this problem?
Username: J_baby15
Kentucky
Post Number: 982
Some HUs have a subsonice filtr built in. I think you can buy external ones too..
Username: Frkkevin
Post Number: 2027
you can buy external SS filters..
Gville, FL
Post Number: 143
where and how much are they?
Username: Southernrebel
Post Number: 3945
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=266-248
problem solved :-)
Gville, FL
Post Number: 144
other than fixing the problem, what other affects would those have on sq?
Username: Adddisorder
West palm, Florida
Post Number: 2170
probably nothing or atleast nothing noticable
Gville, FL
Post Number: 147
i asked scott about them, he said he had no experience with them personally but they must work since they wouldn't be on the market for the last 15 years if they sukt. so canaan, these would allow me peace of mind with pretty much all music?
Gville, FL
Post Number: 149
Gville, FL
Post Number: 150
damn double posts....
Username: Dustin3
Tigard, OR U.S.
Post Number: 4419
yep :-)
Post Number: 3947
yep...i used to run FMODs w/ my bp1200.1 and SX15.
worked like a charm :-)
Gville, FL
Post Number: 151
sweet ill order them right away. i cant wait to join all the Q ppl here!
Gville, FL
Post Number: 152
one more thing, is the 30 the best? it comes in 20 as well.
Gville, FL
Post Number: 153
bump... i just want to make sure i am getting the right ones.
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 661
"they wouldn't be on the market for the last 15 years if they sukt"
why is sony still in car audio...?
