Where can I buy flared ports online? How much port area????
Username: Pike110
12w6v2s, Indianapolis...
Post Number: 280
Does anyone know where i can buy flared ports online. And also I have a box that is 14.5 X 38.5 X 15. I am trying to tune it to around 30 to 32 hz. Can anyone give me some help?
Username: Redliner
Wilmington, Ma
Post Number: 3308
roe
Fi AudioBTL
Post Number: 7548
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=268-352
i just picked up 4 for a little over $50 shipped.
Username: Pike110
Post Number: 281
Does anyone know how long the ports should be. I am going to go for (2) 4" diameter ports.
Username: Southernrebel
Post Number: 3935
pike,
what sub(s) and power are you using?
i make 6" flared ports for $25+shipping.
Post Number: 3936
the box you listed would give you 3.75cuft (gross).
if you are using a sub w/ ~.15-.2 cuft displacment...1 6" port 19.5" long will tune the box to 32hz and give you 3.25cuft net.
1 6" port has more port area than 2 4".
Username: Pike110
Post Number: 282
Damn, I wish I would have waited to make the holes for the 2 4". No turning back now. I am going to be building a few more boxes for different applications and I will hit you up when I need the ports.
Fi AudioBTL
Post Number: 7556
6 inch flared out to how many inches canaan?
also what should i use to stick the flared ends to the center piece? like what kinda glue?
