Crystal pro se
Username: Cenus
Stonerville, Ohio
Post Number: 2547
has any1 ever heared these subs, if so how are they spl and sq wise, im thinking of going with a 10 to try in a new box, would the se work good in a 1.5cf box tuned around 40hz with 100wrms, im looking for a sub that will work good with that box and amount of power under $100, anything better then the se.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 10550
really cant think of any sub better then the pro se for under $100....
great sq sub..low end spl is amazing..good not great on the upper end...but for under $100 there is no better sub
btw: it is better then an AA assassin
Username: Cenus
Stonerville, Ohio
Post Number: 2548
LOL i knew you would answer chauncey, so would the se work in that box i mentioned, and would 100wrms be enough for it.
Post Number: 10551
100rms would be cool...they are really good when it comes to power...i mean 200would be better but 100 would work fine...go for it...
Username: Cenus
Stonerville, Ohio
Post Number: 2549
awsome, is there any place cheaper than ROE to buy them, and would it be worth the extra $10 for the 12 instead of 10.
Post Number: 10555
cant think of anywhere cheaper...and the bigger the better imo
