Amp to power 12" Kicker CVR
Username: Gibson5469
Post Number: 48
Im picking up a 12" Kicker CVR 4 ohm single coil sub (for $50 ), I need an amp to power it.
I need something that's fairly cheap, $150 or less if possible. The specs for this sub are 150 watts RMS and 300 watts peak.
There are a few amps from Clarion and Power Acoustik for sale on www.sounddomain.com that meet these specs with no problems and are all priced at $100 or less.
Any ideas? opinions on the companies I listed?
Thanks in advance.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 10553
https://www.ecoustics.com/electronics/forum/for-sale/296048.html
i will sell for very cheap let me no...
Username: Tjmutlow
Post Number: 3298
cvr's came in dual 4 or dual 2 ohm , I have never seen them single 4 only the comp sereis.
Post Number: 10557
^^X2...i think he means the Comp...look at the power ratings...
Post Number: 49
guess it is a 12" comp. so what do you all think?
won't that bazooka you are selling over power the sub? it pushes 300 watts rms at 4 ohms, so double what this can handle
Post Number: 10564
those are @ 14.4volts...if you dont have an electrical system upgrade....then it would work perfect for you...and like i said..im not looking to get alot..
Username: Tjmutlow
Post Number: 3302
LOOK AT AN AMP THAT DOES 400-600W AT 2 OHM, lik ethe kicker zx series.
Username: Logan__tille
Post Number: 2891
kicker zx400.1
