Dual 4 ohm or dual 2 ohm?
Username: Rustysurfer916
Oviedo, FL
Post Number: 245
ok i wanna get a kicker zx1500.1 and 2 12 inch kicker CVX's. do i get the 2 ohm subs? or the 4 ohm subs? i know if you get one 4 ohm sub you can wire it in parallel to make 2 ohms but its a mono amp so theres one channel. can you get 2 ohms out of 2 2ohm subs? i dont know a whole lot about how ohm ratings work and all that stuff.
Username: Grebnereon
Post Number: 515
wtf, i just posted on this!!!
anyway, get the dual 4 ohm subs, you will wire each coil on each sub together, making each sub 2 ohms, the wire both subs together, making your overall resistance 1 ohm
Oviedo, FL
Post Number: 247
i want my overall resistance to be 2 ohms. oh yeah i forgot to mention that.
Username: Tjmutlow
Post Number: 3282
dual 2 ohm, amp is only stable 2 ohms.
