Is this possible....
Username: Lilsherm51
Johhnstown, PA US
Post Number: 19
i have:
- 2 12" kicker compvr 2ohm DVC
- 2 12" kicker compvr 4ohm DVC
is there a way to safely wire them to 1ohm, or as close as possible? im not even sure if you can mix subs on a mono amp.....i suck at wiring so id appreciate it if you guys could help me out here .....thanks
Username: Skies
Courtenay, British Colu... Canada
Post Number: 358
it is possible, but NOT recommended.... because the 2 of the 4, depending on how you wire it will be getting more power than the other 2.
Username: Tjmutlow
Post Number: 3288
you can not get to 1 ohm, 1.5 ohms, running the dvc2ohm to .5ohm per pair(paralle/parralel), the the dual 4 pair down to 1ohm load(par/par), the run them series together, creates a 1.5 ohm load. the amp will push power at a 1.5 ohm laod., personally, I would just run the dual 4 ohm pair.
Username: Blainew
Diamonds in the back.
Post Number: 1884
dont mix the ohms....ur subs wont get the same power
