Need help.
Username: Rvlacos
DD 3512 United States
Post Number: 911
}i need to find a wire harness for a cd player: alpine cda-7893. i tried google and ebay. its a special harness they say some of the ones on ebay will work but really they wont if you wanna use the built in v-drive amp. the wire harness needs to have a special wire to be ran to the battery with an inline fuse! somebody help!
Username: Rvlacos
Post Number: 915
bump!
Username: James1115
Ct
Post Number: 7489
I believe any v drive harness will work. the 9813-9815 are both v drive check them out. The only difference is the v drive harness has a thicker power wire. what about this one? http://cgi.ebay.com/ALPINE-Wire-WIRING-Harness-CDA-7892-7863-9813-9833-BLK_W0QQi temZ190057215642QQihZ009QQcategoryZ32812QQtcZphotoQQcmdZViewItem
Username: Rvlacos
Post Number: 979
it says it will work and it sounds like it will work but alpine told me i need one with an inline fuse to the bat. maybe i just add a 20 amp fuse?
thanx james!
