How will this amp and sub match up for SQ?
Username: Paulmasoner
Honolulu, Hawaii Usa
Post Number: 34
1 cube sealed box..Infinity Kappa Perfect 12DVQ@2 ohms with Memphis 16-MCD500
I'm still open to ideas for the best SQ setup at or above 300 watts with a 12" and combination price range of 500
Username: Redliner
Wilmington, Ma
Post Number: 3100
u could for 500 bucks get a stereo integrity mag now cause they are in a group sale so technically you could do the mag for whatever it is going to end up around which should b around 325 or something like that so then u could have 175 left for a amp which i would recommend this amp for a budget cause i own it and have never had a problem and it def puts out what it says http://cgi.ebay.com/NEW-MTX-THUNDER-942-CAR-2CH-940W-SUB-AMP-AMPLIFIER_W0QQitemZ 140055861363QQihZ004QQcategoryZ39735QQssPageNameZWDVWQQrdZ1QQcmdZViewItem but that is if u could go a little bit over 500 trust me it would b worth it to go from a infinity to this
Username: 54danny54
KY More Wang Th...
Post Number: 2967
he also said the 300 watt range..
use the 12 inch assasin
www.ascendantaudio.com
and this amp
http://cgi.ebay.com/PHOENIX-GOLD-X400-1-LPL44-D2-MONO-CAR-AMP-BASS-REMOTE_W0QQit emZ270058294057QQihZ017QQcategoryZ18797QQrdZ1QQcmdZViewItem
Username: Ctmike
Ct.
Post Number: 2569
he did say at or above 300w. i say go for the mag.
Username: Redliner
Wilmington, Ma
Post Number: 3104
"or above 300 watts with a 12"" he said or above so huh lol
