Product Name: 1600 Watt Mono-Block Class D Amplifier MSRP: $919.00 Product #: HP-1600 Description:
Power Output at DC 14.4V RMS Power 1200W x 1 @ 4 Ohm RMS Power 1600W x 1 @ 2 Ohm RMS Power 2000W x 1 @ 1 Ohm Signal-to-noise ratio: > 100dB Frequency Response: 5Hz - 250Hz Total harmonic distortion: 0.1% Continuously variable 0 - 18dB BASS boost Built-in continuously variable 24dB per octave crossover Input signal sensitivity: 0.15V - 5V Voltage sensitivity: 100mV - 18V Fuse Rating: 40A x 3 Optional Remote Bass Volume Control (remote RM-HP available separately) Engraved Concept Logo Gold connectors Dimensions (L x W x H): 19-1/2" x 6-6/7" x 2" Weight: 18 lbs Small footprint Marine Grade
