Bronze Member Username: PaulmasonerHonolulu, Hawaii Usa Post Number: 19 Registered: Oct-06 | I have made up my mind after listening to many subs lately. I am getting a 12" L7 mounted in 1-1.5cube sealed box(any input here would be nice, looking for clean sound)... whats a good amp to push it in the range of 250-300? |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 10330 Registered: Jul-05 | never seal L7's its a waste...look into a kicker zx 750.1 |
Bronze Member Username: PaulmasonerHonolulu, Hawaii Usa Post Number: 20 Registered: Oct-06 | why never seal one.. ? waste of its potential power? i dont care about the power, i'm gonna be listening to some odd music and it has to be very very precise |
Bronze Member Username: PaulmasonerHonolulu, Hawaii Usa Post Number: 21 Registered: Oct-06 | why never seal L7's waste of their potential power? dont care.. gonna be listening to weird stuff it HAS to be precise...un less you got some other ideas for a 12" with really good-great SQL in the range of 175-250 bucks |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 10334 Registered: Jul-05 | i use to own 4 L7's...u will not get real good sq with those....they are meant to be ported(cheap daily spl) nothing more...nothing less |
Silver Member Username: Tdawg30Ohio USA Post Number: 660 Registered: Jun-06 | get logans sd2.5's in the for sale section. he has em up for 280 shipped. very very good deal. check it out |
Silver Member Username: Mvplefty12Pinellas, FLA America Post Number: 284 Registered: Mar-06 | I would do a 12" Fi SSD or even a single AQ SD2.5 12"... If you save 10 more dollars you can get an FI Q!!!... Save even more money and you can get the S.I. Mag from our group buy on here, they don't get more precise then that! Thanks, Andrew |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 10342 Registered: Jul-05 | "they don't get more precise then that!" yes they do..they just cost way more. |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 1742 Registered: Nov-05 | if ya need an amp... ive got one for sale https://www.ecoustics.com/electronics/forum/for-sale/292446.html |
New member Username: Audiobahn805FILLMORE, CA USA Post Number: 1 Registered: Nov-06 | kicker is for high spl not for sq but one L7 goes great with the kicker kx750.1 or the zx750.1 which is the same but just newer model. |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 10353 Registered: Jul-05 | " kicker kx750.1" ^^^Nope doesnt exist... a kicker kx600.1 was replaced by the zx750.1 |
New member Username: Audiobahn805FILLMORE, CA USA Post Number: 5 Registered: Nov-06 | yeah you are right i made a mistake it dosent exist |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 10360 Registered: Jul-05 | no harm no foul |
