Audiobahn Subs
Username: Huskermike
Post Number: 7
Thinking about getting two Audiobahn 10" subs, specifically AW1008T. If I can get two for $200, would that be a good buy, or is there better out there for the money?
Username: Tonybones
Post Number: 97
You would be better off getting 2 12's for that price range. I would go wtih 2 kickers
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 10232
much better for the money...
do u use ebay??
will u buy online???
do u want spl(loud) sql(loudand sound good) or pure sq(sound good)??
do u already have an amp??
budget??
Post Number: 8
I would go with two 12's if I had the room, but my trunk is pretty small and two 10's barely fit. I use eBay and have no problem buying online. I'm more for SQL or SQ than SPL. I have an Infinity sub amp that I had running 650 RMS to two Infinity 10's, and that's what I'll be running the new subs with until February at least. I'm trying to stay around $200 for subs and box(es); I already have two 10" boxes, and as I said my trunk is small, so those two things were why I'm looking at 10's.
The Audiobahns were recommended from someone who owns the 12" version and likes them a lot, so I thought I would see what people here thought. Thanks!
Post Number: 9
What about Kicker Comps or Alpine Type R's? Recommended, or not? What are the main differences between them?
Username: Livin_loud
Ny
Post Number: 453
The R's have a little more sound quality to them while the Kickers get a little bit louder
Username: Logan__tille
HD3, Www.Audioque... United States
Post Number: 2486
Audioque SD2....
Username: Kyle_lowe
Post Number: 114
just get one mag
Username: Drivingreckless
TREO, USA
Post Number: 2356
x2 :-)
Username: •cam•
Post Number: 14
two assassin 12s maybe?
Username: Extrmndor3
Friday, Str8t to the Gentlemans club
Post Number: 2647
kicker and alpines will not get louder than those aw1008t they will sound nice but not louder and its a good buy the kickers will sound worse than those aw100t but the type r will sound better but not as loud as the aw1008t
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3389
ID MAX
Username: Rvlacos
DD 3512 United States
Post Number: 442
there is always better than audiobahn!
Username: Basshead86
OG eCoustics Member
Post Number: 8810
Always....
Username: Rvlacos
Post Number: 461
and audiobahn just realized this so they r goin outta business!
