Adjusting gain with dmm
Username: Thumping_corsica
Saginaw, miUnitd states
Post Number: 150
i just got a dmm. now what do i do to set the gain?
Username: Frkkevin
Post Number: 1700
what is the RMS power and what is the ohm load..
Fi AudioBTL
Post Number: 7211
http://www.subwoofertools.com/forum/setgain.asp
Username: Frkkevin
Post Number: 1702
well yeah that works.. i was going to tell him the process
one thing to keep in mind is box rise.. i always set my gain voltage a little higher than my target voltage because of the box rise. i don't know how to figure the exact voltage but im sure marshall does
Post Number: 152
amp is 600 rms by 1 at 4 ohms
Post Number: 153
what hz to i play the tone at? 50 hz?
Fi AudioBTL
Post Number: 7216
yeah i use a 50hz.
Username: Frkkevin
Post Number: 1703
depends.. i'd use the note your box peaks at.. play a note that is 8-10hz higher than your tuning frequencu.. you should be looking for 49v but i'd set the gain between 50-52v
Post Number: 154
1 more question... what do i set the dmm to?
"dcv 5" "dcv 25" "dcv 125" "acv 50" or like "acv 10"? thx
Username: Frkkevin
Post Number: 1705
ive always set mine to 200acv
Post Number: 156
ok so will 250 acv do?
Fi AudioBTL
Post Number: 7233
setting it at 250 acv will still give you the readings. mine just has 200 and 500 acv but i guess you got one that has more options.
Username: Frkkevin
Post Number: 1706
yes.. 250 acv will work fine
Username: B101
DD, RE, FI, TREO, KICKERUSA
Post Number: 3930
lol dmm 101
if you are estimating a measurement of 6v, your should set the dmm to a 10v scale..
basically you always want to use a larger scale than what u are meassuring or estimating from calculations!
dont use to high of a scale, like 1000 to measure something in the 10ths ... etc...
