Cotton in your box????
Username: Mike20
Post Number: 54
When i got my jl audio box from someone it had Like cotton all in it.. It sounded good with the Jl audio sub, but i put my alpine x-10 in it and it doesnt sound good. Could all the cotton be messing up the sound because of the major size difference in the sub? The X-10 has a hole on the bottom of the magnet, so if theres like cotton pushed up against it could it be messing with the sound?
Username: Ctmike
Ct.
Post Number: 2406
what size is the box? the polyfill (cotton) is to make the sub act like it's in a bigger box. could be the box with polyfill is to big for the x.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 10141
cotton?? DO u mean polyfill??
and it may not sound good because the box is not built to sub specs
Username: Basshead86
OG eCoustics Member
Post Number: 8710
silly marhefka. you make me laugh:-)
Username: Redliner
Wilmington, Ma
Post Number: 2972
it just makes it seem like the box has more room then it does but build a box to spec lol
Username: Mike20
Post Number: 55
Ey i dont know all that much about this stuff.. Looks like cotton to me.. Thats why i ask, i kno you guys usually know.. I know someone to build a box for me but how do i know the exact specs.? And id go for a sealed box, easier to build right>?
Username: Ctmike
Ct.
Post Number: 2409
i'd go sealed with the x. alpine recommends .5-1.0 cuft sealed.
Username: Mike20
Post Number: 56
Thanks.. Im prob. gonna piss someone off, but i cant buy one thats got the specs. i need .5-1.0 cu ft.??? Its jus so much easier than gettin this dude to build one.
Username: Redliner
Wilmington, Ma
Post Number: 2977
build one it will b better it will b worth it in the end
Username: Tdawg30
Ohio USA
Post Number: 625
yeah
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 519
buildin is better than pre fab!
Username: Tjmutlow
Post Number: 3206
sent you a pm
