Door pannel help
Username: Steve_collins
Post Number: 226
how do i change the stock speakers in my 1998 jeep grand cherroki. it looks like the door pannels are glued on because i cant find any screws. help needed thanks a lot.
Username: Moondogg1212
Post Number: 58
they probably have pins that hold it on. try popping it off. you might have to take your door hadle apart though. just a thought.
Username: Leew
stealth fighter , Yokosuka, ... SPESNAZ. ...
Post Number: 828
Remove trim cap and screw near rear of door armrest.Remove trim cap and screw at upper front corner of trim panel.Remove screw locaited above front door speaker grille.Using a trim stick,gently pry around perimeter of trim panel.Disconnect door module connectors and door courtesy light connector(if equipped).Remove trim panel!
Post Number: 59
i was wrong. lol.
Username: Leew
Post Number: 829
ah..forgot!
before(what is above)!Remove bezel near inside door latch release handle by inserting a flat screwdriver in notched end and prying gently upward.remove door trim panel mounting screw located in bezel opening near inside door latch release handle!
Username: Nyyfan13
VA USA
Post Number: 831
montana, how many times are u gonna change your name? and are you jen with a new 250 dollar name?
Username: Alias747
Eclipse Ti, MN
Post Number: 1612
Hey Jen where did you get that information about the door panel?
leew, now thats a 250 dollar name alright
Username: Leew
stealth fighter aka j..., Yokosuka, ... SPESNAZ. ...
Post Number: 832
yea right $250,,,and now I am looks like chinese!
About the door: Last week I did repair a mirror ! on ours patrol car,so I still remember ...
