Parking brake wire
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1212
I just installed my Eclipse AVN6600 and I need to bypass the parking brake wire. Do I need to short it to ground or voltage? I think it may be ground. Anyone know for sure?
Username: Sinful_systems70
Post Number: 79
Just put it on a switch. That way you don't have to pull parking break for the deck to play video and you don't have to worry about messing with wires and the answer to your question.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1323
thanks man, but i just wired it straight to ground and now it thinks that the parking break is always on. i dont have to bother with a switch.
