New member Username: NolimiyPost Number: 7 Registered: Nov-06 | I'm looking to place 2 12 SI Mags in the trunk of my 2002 626. I have heard through SI's website that the minimum recommended port cu ft is 2 per sub so the question becomes this: what would the physical external dimensions of the box be for these 2 12s? I'm seeing a lot of epople but huge boxes behind these subs but i'll be powering it with a Sundown SAZ-1500D so it's not like I'm overpowering the subs by too much... the amp is rated at 1500@1 ohm and I've heard a lot of people say it's underrated and should be around 1700-1800 watts @ 1 ohm. Thanks for your help |
