How do you keep slot ported from having port noise??
Username: Pike110
12w6v2s, Indianapolis...
Post Number: 244
How do you "flare" a slot ported box to keep it from having port noise? Also, does anyone know where you can buy box carpet that isn't the standard black or grey? Maybe some with graffix on it or just something different?
Username: 54danny54
Betsy layne, Kentucky..GO... \blink, red,...
Post Number: 2903
did u use the www.subwoofertools.com subwoofer box calc? if so it should have gave u enough port area to cut out port noise.
Username: Rovin
Trinidad & T...
Post Number: 9796
..ya - i thought slotported boxes were designed 2 never have any port noise ,never heard any in of my slot boxes so far ...
Username: Pike110
Post Number: 246
Mat Dope gave me a box design that I am going to use. I had another thread earlier that was titled "Can someone help" This is the first ported box that I have ever made so I was just making sure I wouldn't get any port noise.
Username: Rovin
Trinidad & T...
Post Number: 9797
try it out & live a little on the edge man ......
Username: Frkkevin
Post Number: 1685
use a router to round the edge of the port.. also you can use quarter roud of something similar for the corner
Username: Southernrebel
Post Number: 3827
round all edges of the port and make sure you have at least 12sq inches of port per cuft.
~16sqinches per cuft will do better.
Username: Rovin
Trinidad & T...
Post Number: 9798
good advice from mr. "canaan".......
Username: Pike110
Post Number: 248
Its been awhile since college. To get the sq inches of the port is width x height or width x length. Sorry for the stupid question. measurments of the port is 4" width x 12.5" tall x 14.75" length. It is a 2 cube box. Does this sound right? Its for 2 12" assassins.
Post Number: 3831
do you mean the box is 4cuft? (2cuft per sub)
u measure the opening the port creates...
4" x 12.5" = 50sq inches
50sq inch / 4cuft = 12.5sqin/cuft
That box doesnt sound right though...4cuft w/ 50sq in port 14.75" long would tune to ~40hz. I would tune those 12's to ~35hz for daily.
Username: Pike110
Post Number: 249
Here is the box that I got from Mat. Does this look right to you? The AA website says 2cf and tuned to 32hz for the assassins.
application/pdfUpload
Assassin12dualportedboxplans.pdf (40.5 k)
