Shaking my rear window.. problem?
Username: Caraudio
Toronto, Ontario Canada
Post Number: 756
I got 1 CVX with a T3002 amp at 2ohm bridged i put my gain on about 80% of the way .. and HU settings are nominal i have the bass at +4 but the sub level at -2 just for some midbass from my 6.5" speakers. S0o0o i notice that my rear window also shakes with my trunk is that bad i dont want the window to start leaking or anyhting. Its a 2005 Civic.
Username: Andrew571
Post Number: 202
it should be fine. unless you see the seal breaking or coming apart, i dont see anything bad.
btw thats a pretty stout gain setting
Username: Oglejust
15in re sx, Il Us
Post Number: 379
ok theres 2 things u have to do... 1st make a video of that bish...and 2nd TURN IT DOWN!
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 3341
I dont like when people put their gain in percetages or fractions. what i dont understand is why would anyone not have their gain all the way up? all the way meaning matching their Hu preouts which puts out full clean power. mainly they are talking about the percentage of the way they turned the knob though which means nothing and is useless to the people trying to help.
Username: Caraudio
Post Number: 758
okay well my HU is a 4 Volt Preout.. what does that mean .. 4Volt Pre out on my amps how far on the high side?
Username: Caraudio
Post Number: 759
Panasonic CQ-C5310U This is the model.
