Weird sub noise
Username: Atomiclee
Post Number: 32
I have 2 Xtant X1244 subs in a sealed box. When I turn it up, one of the sounds makes a popping noise like if you put a piece of paper or plastic in front of it. If I push in the center a little bit, the noise stops. Does anyone know what this might be?
Username: Basshead86
Try Google
Post Number: 8242
blown VC sounds like to me.
Username: Atomiclee
Post Number: 33
Can I take it somewhere to get it repaired or should I buy a new one? I really dont feel like spending 400 bucks to repair it.
Try Google
Post Number: 8325
400 bucks to repair it??????????????????????????
dang dude...a recone shouldn't cost that much...you are getting r*ped...
Username: Atomiclee
Post Number: 34
No man, 400 bucks for a new one..haha I missed typed that one. Is it worth getting reconed or should I just buy a new one or build a box for just 1 12?
Try Google
Post Number: 8330
get it reconed.
Username: Dustin3
Tigard, OR U.S.
Post Number: 4061
does it sound like the cone is scrapping against the side of the box or somthin? sounds like a VC problem, but you shouldnt have to get the WHOLE sub reconed, if its just a blown VC.. or do you?
Username: Atomiclee
Post Number: 35
bassman3-as soon as it gets to a certain volume level, every time it hits it makes kinda like a popping noise. If I keep it low, it sounds normal.
