Need more spl!
Username: Sam_04290
Post Number: 8
Allright guys I Have a Idmax 12 in a 1.75 sealed box and i think i need more spl,which are some subs that would compare in sq but get louder or should i but another idmax?help i was hinking a brahma but i heard the sq isnt that good thanks
Username: Grebnereon
Post Number: 436
ok, first off, what you have has potential to be considerably louder. all you need is a bigger, ported box. how much power do you have going to it?
Username: Redliner
Wilmington, Ma
Post Number: 2844
another idmax if u buy new subs ur most likely not gonna have the same sq since idmax's are amazing sounding. Just get another one and port them
Username: Sam_04290
Post Number: 14
I have a pheonix gold 600.1 if i get two iam going to upgrade to a pg 1200.1 or a jbl 1200.1
i want to make a bigger box and port them and i have all the dimensions...just i dont know how big to make th port size...for a 2.0 cubic ft box tuned to 32 hz
Username: Talon_es93
Trinidad, Co
Post Number: 414
http://www.carstereo.com/help2/Articles.cfm?id=31 go here man this helps out alot..this will tell u what u need to know
