Down to the woofers
Username: Mr_kebo
Albertville, Al USA
Post Number: 737
We have 1.3cubes sealed per 2 woofers. 2.6 total between 2 chambers. We are down to these choices.
4 RE SR10", 4 eD 11kv2 or 4 10" RL-i. Looking for the most spl. we are doing this cause he wants to retain his back seat in the ext cab truck. All setups will have 1 eD NINe.1 amp for power.
Username: Mr_kebo
Albertville, Al USA
Post Number: 738
http://www.supercrewsound.com/shop/detail/11/192.htm thats the box if you wanna see it and maybe suggest some other subs that will work. When i get the box im gonna put another bead of glue on the corners and coat the inside with resin for some more strentgh since it uses 5/8 mdf.
Username: Mr_kebo
Albertville, Al USA
Post Number: 739
any suggestion
Username: Southernrebel
Post Number: 3733
i would go w/ the RLi 10's...i have heard the 8's before and they sounded amazing.
Username: Adddisorder
West palm, Florida
Post Number: 1692
x2 on the rl-i's
