Sub and amp?
Username: Shade
Kenwood KAC-7202
2x TYPE R SWR-1242D 12" Dual 4 Ohm
1.75 sealed q-logic box
inside a dodge neon?
thnx in advance^
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 428
I have heard a lot of negative about qlogic boxes...
Username: Stnorris
Davenport, IA US
Post Number: 1543
different amp. i think thats a 2 channel amp (if looked up the right one), plus it only does 460rms bridged.
Username: Shade
so 230rms is not good enuff for these subs? and should i stuff the box? or will it not make a diff.?
Username: Volfenhagking1600
Atlanta, Georgia USA
Post Number: 146
i stuffed my q logic and it made quite the difference.
Username: Shade
ok, so what can i expect outta these speakers/amp and how should i wire the subs?
