Help please amp pic.
Username: Kickdoor
RE SX
Post Number: 137
well i won a rockford 800.2 amp off ebay but it has two things like to connect two grounds and two power wires do i have two run two power wires and two grounds to it? im gonna use it two run two 200rms subs at 4ohmsx2 until i order a 12" FI ssd thanks
Fi AudioBTL
Post Number: 6851
i used to have the four channel version of that amp. the other + and - is for connecting a cap to it. at least thats what the manual that came with my amp said.
according to the manual, you use the outer + and outer - to connect power and ground and the inner ones are for caps.
Fi AudioBTL
Post Number: 6852
caps = capacitor
Username: Kickdoor
RE SX
Post Number: 138
cool thanks chad i tought it was because it probably had two power supplys or something lol
do i need the flatwin coil and copper coil on the ssd? im not sure what theyre for but i wanna know before i order tommorow
