Username: Devastation101 Post Number: 168 Registered: Feb-06
Friday, November 03, 2006 - 02:05 GMT do you have any pics of your SD2.5's? What are you powering them with?
Username: Logan__tille AudioqueUSA
Post Number: 2229 Registered: Feb-06
Friday, November 03, 2006 - 02:10 GMT i have pics of them. no amp yet. waiting on a kicker kx 12OO.1 from mick. i have them hooked up to a friends memphis prd 1OOO.1 and they pound.
Username: Devastation101 Post Number: 172 Registered: Feb-06
Friday, November 03, 2006 - 02:14 GMT Do you have the exact specs for them yet? And another question, why did you recommend that kx1200.1 instead of lets see, two 600 watt amps?
Post Number: 2230 Registered: Feb-06
Friday, November 03, 2006 - 02:21 GMT
Post Number: 2231 Registered: Feb-06
Friday, November 03, 2006 - 02:26 GMT
Post Number: 2232 Registered: Feb-06
Friday, November 03, 2006 - 02:29 GMT
Post Number: 2233 Registered: Feb-06
Friday, November 03, 2006 - 02:33 GMT
Username: Devastation101 Post Number: 174 Registered: Feb-06
Friday, November 03, 2006 - 02:36 GMT How's the excursion on those things? Man, I'm so freaking anxious to buy the other and get them installed!
Post Number: 2234 Registered: Feb-06
Friday, November 03, 2006 - 02:36 GMT ops^^that pic isnt supposed to be there. I thought it would be easier to use 1 amp instead of 2. also, what do you mean by exact specs?
Post Number: 2235 Registered: Feb-06
Friday, November 03, 2006 - 02:37 GMT when i had one hooked up to my JBL GTO6O1.1II, it had some nice excursion. i just cant wait to get my kicker.
Username: Devastation101 Post Number: 175 Registered: Feb-06
Friday, November 03, 2006 - 02:44 GMT Like honestly, I already purchased one of the subs, and I don't know even know how many Ohms they are. When I said exact specs, I meant a more specific spec sheet than what they offer online
Post Number: 2237 Registered: Feb-06
Friday, November 03, 2006 - 02:56 GMT they are dual 4ohm, 5OOrms but DJ from audioque said they can take 1OOOrms if your careful.
Post Number: 2238 Registered: Feb-06
Friday, November 03, 2006 - 02:57 GMT lol. i hoped that helped a little. if you had specific questions i might be a little more helpful.
Username: Devastation101 Post Number: 177 Registered: Feb-06
Saturday, November 04, 2006 - 07:34 GMT Oh ok, that's good enough! So honestly, a 1500-2000 watt mono/ 1ohm stable amp might be good enough for it?
Post Number: 2273 Registered: Feb-06
Saturday, November 04, 2006 - 15:59 GMT I wouldnt go 2OOO, i would go 15OO.
Post Number: 2274 Registered: Feb-06
Saturday, November 04, 2006 - 16:00 GMT just keep the gain and the bass boost down low, because thats what kills subs.
Username: Devastation101 Post Number: 178 Registered: Feb-06
Saturday, November 04, 2006 - 16:16 GMT Really? Honestly, I thought whenever you turned the gains and the bass boost UP, that's when you get the full wattage of the amp. I need to be schooled more! lol Around here, every one I know thinks that SUPER LOUD is the thing to go for. I was always taught to keep the Bass Boost all the way up and the gain Half Way. I just learned that the gain is supposed to be aligned with how ever many Volts your preouts are on your HU, right? Anyway, these are the same guys who taught me that Rockford Fosgate, Audiobahn, Kicker (Comp Series, not squares), and get this CRUNCH, are the best SUBS known to man! lol I need to be re-enlightened!
Post Number: 2277 Registered: Feb-06
Saturday, November 04, 2006 - 16:26 GMT lol. You are right about gain and the HU voltage. But never turn you bass boost all the way up. It is horrible on your subs. Alot of people dont use the bass boost. Actually i would not turn the Bass boost up more than 1/4 of the way.
