Subwoofer NOiSe......
Username: Mike20
Post Number: 14
what the hell is it when theres a popping noise coming out of the sub every so often..???? Just started like 20 minutes ago when i was driving.. Havent went through anything, anyone fot an idea????
Username: J_baby15
Kentucky
Post Number: 736
man I had that with my treos and couldnt figure out wat was wrong wit it...it kept gettn louder, then i figured out it was the dust cap floppin around.lol. I doubt thats ur problem tho, but its a start.
Username: Volfenhagking1600
Atlanta, Georgia USA
Post Number: 143
You are clipping ur subs
Username: Basshead86
Try Google
Post Number: 8215
that popping sound is the VC hitting the backplate...they aren't the best of friends...try to keep them away from each other.:-)
Try Google
Post Number: 8216
or quite possibly you need to check your grounds...
Username: Renegadesrun
Lafayette, IN US
Post Number: 496
Grounds? Wtf?
Username: Luisdelbronx
Bronx, NY USA
Post Number: 39
i had a loose ground once and everytime i took a bump the subs would make a popping noise.
Username: Grebnereon
Post Number: 419
im with you Ren........stumped me
Try Google
Post Number: 8227
so far we have Fi, eD, A8000t, What's your budget, and now...check your grounds...:-)
Username: Extrmndor3
Life is GOOD, Ill Us
Post Number: 2415
there alot of things that makes that sound like:
check ur woofer wiring maybe u got them unwire them in one coil
u got wired ur subs bad make sure they are wired in a good impedance
ur clippin the subs
ur amp needs more current (its clippin the amp and the subs)
check the gains
yeah check the ground those are really important
