Everything is in
Username: Nyyfan13
VA USA
Post Number: 544
well, the final pieces of my system came in today being the speakers and wiring. everything is ready for install which will hopefully be this weekend.
this will be my first install so be on the lookout of questions on here cause im sure ill have many.
how long do u think it'll take to install?
Fi AudioBTL
Post Number: 6783
fukkkk waiting til the weekend yanks fan. get your azz outside now and start installing.
oh and don't forget pics. we love lots of pics of installs. lol.
Username: Nyyfan13
VA USA
Post Number: 545
haha, i gotta start this weekend cause i gotta carpet the box tomorrow nite. and i cant do anything cause i gotta wait for my dad to get back in town, hes in Cal, and he gets back late tonite.
and dont worry, ill take plenty of pics of the install. i shold have them up probably tuesday nite, when my sis brings home the digital camera from her college.
Username: Nyyfan13
VA USA
Post Number: 551
how long do u think it'll take to install HU, 2 amps, sub, box, set of comp speakers?
*first install ever*
Fi AudioBTL
Post Number: 6785
damn too long. lol. always some problem occurs so i had to go back and re do everything again.
Username: Drivingreckless
TREO, USA USA
Post Number: 2145
13 hrs
if u have absolutely no clue wut ur doin
5 hrs if u no wut ur doin
Username: Nyyfan13
VA USA
Post Number: 553
well, it looks like its gonna be a long weekend for me. im thinking im up in the 13 hr range. maybe less tho.
Fi AudioBTL
Post Number: 6786
make sure you have everything you need in front of you when you start your install. one thing i hate is having to run to the store in the middle of an install cause i forgot it before i began.
TREO, USA USA
Post Number: 2148
today and tommorrow u should experiment poopin of ur trim and dash to make it easier for u
also u need a wiring diagram for u car to wire an HU
Username: Nyyfan13
VA USA
Post Number: 554
im pretty sure i got everything i need, i got all the wiring and everything. ill find out how it goes this weekend.
expect many questions on here
Fi AudioBTL
Post Number: 6787
may the force be with you!
Username: Nyyfan13
VA USA
Post Number: 555
haha well thank you sir
Username: Nyyfan13
VA USA
Post Number: 557
where can i find a wiring diagram for 2005 scion tc for my HU?
cant find one off google
Fi AudioBTL
Post Number: 6789
just buy the wiring kit.
Username: Nyyfan13
VA USA
Post Number: 559
does this happen to be the same as a "dash kit/mounting kit?"
Fi AudioBTL
Post Number: 6790
well there is a kit for each car. you just unplug the stock stereo and plug in the kit and wire the hu to the kit.
Username: Nyyfan13
VA USA
Post Number: 561
ok, so all the wires that came with the new HU is all the wires i need to install it, correct?
and since im at it, whats the best way to take out a HU?
Username: Nyyfan13
VA USA
Post Number: 565
bump... for an answer to the best, easyist, and most efficient way to take out the HU?
thanks
Username: Troy81
Tavernier, Fl Us
Post Number: 1341
well, i dont know about scions, but most cars have some kind of trim that pulles off, it might be held on with cips or screws, but theres almost always something, ive done cars that were the whole dash, if you have pictures i could make some guesses as to where to start
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 423
Some cars have "keys" you have to have to get the stock HU out
Username: Troy81
Tavernier, Fl Us
Post Number: 1349
yeah, my lexus(toyota) which is probably like your scion(toyota) had little clips inside the air condition vent, get a flash light and see if you can see little things that push down, and be careful, i broke my airvents trying this :-(
Username: Basshead86
Try Google
Post Number: 8162
good luck Yanks Fan!:-)
Username: Nyyfan13
VA USA
Post Number: 566
well thanks, and when i get home today from school, ill take some pics and let u take a look at it and take some guesses
Try Google
Post Number: 8194
SWEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEET
i love pics.....:-)
Username: Frkkevin
Post Number: 1488
do yourself a favor.. go invest in some HEAT SHRINK... trust me .. you'll love me later
Username: Nyyfan13
VA USA
Post Number: 567
where can i buy heat shrink and what does it do?
im at school
Username: Frkkevin
Post Number: 1489
any autoparts store.. radio shack is another place that would carry it.. you slide it on the wire before you make the connection.... slide it over the splice and heat it with a lighter. it then shrinks around the wire insultating the splice. its like using black tape except much easier and cleaner and it is not going to fall of...
Username: Andrew571
Post Number: 175
GET TO WORKKKKKKKKKK
Username: Nyyfan13
VA USA
Post Number: 568
alrite that sounds good kevin. thanks
and chill andrizzle, ill get to work when i get the chance.
Username: Nyyfan13
VA USA
Post Number: 569
thats my current HU right now, any idea from looking at it, how i take it off?
thanks
Username: Nyyfan13
VA USA
Post Number: 572
alrite and, i just realized that i need a speaker(?) terminal for the wires to come out of the box for my sub.
would best buy carry one of these?
Username: Nyyfan13
VA USA
Post Number: 575
bump for an anser to either of my lastest questions...
thanks
Username: Andrew571
Post Number: 177
u can get them on ebay for like a dollar and $2 for shipping..
and i dont think bestbuy sells box 'parts'
Username: Nyyfan13
VA USA
Post Number: 576
i dont wanna order it cause im installing it tomorrow and sunday...
how about a local car audio store?
Username: Andrew571
Post Number: 179
yea i guess, go to a local car audio shop and say ull givem a few bucks for a terminal cup
Username: Nyyfan13
VA USA
Post Number: 577
alrite good deal thanks bud.
how about an answer to pull out the HU posted above? any comments? anyone?
Fi AudioBTL
Post Number: 6808
just drill some holes and run the cable straight to the sub. i don't like those terminals. make sure you seal the hole around the cable though.
Username: Nyyfan13
VA USA
Post Number: 579
so i could just cut a small little opening for the wires and then just seal up the opening with the wires in it with caulk or something?
