Can the fi q and aq hd3 take 1500 watts daily??
Username: Pike110
Post Number: 216
I am thinking about getting both of these subs and keeping the one I like the most and selling the other. They are rated at 1000 watts rms and I have a soundstream pca-1500 which is supposed to do "1500" at 1ohm.I was just making sure this wasn't going to overpower them. I think they can take it.
Username: Sb2012
Iowa US
Post Number: 420
the HD3 can take 3k daily...and has been burped over 6k before...:-)
as for the FI Q...im not sure...someone on here said Scott said not to put more than 1500wrms to it..u might be pushing it with 1.5k IMO...
Username: Drsmith
Montana USA
Post Number: 1603
agreed lol
Username: 54danny54
Betsy layne, Kentucky..GO... USA duh
Post Number: 2819
the HD3 im not sure bout the 3k watts thing. the DD9500 i know can take 3k daily. the reason i say that for the HD3 is because it dosent have the cooling as the 9500 does.
Username: Djl
Post Number: 14
At that power level there will be no significant differance in cooling between the HD3 and the DD9500.
Username: Adddisorder
West palm, Florida
Post Number: 1638
the Q should be fine with that power.
Username: Dustin3
Tigard, OR U.S.
Post Number: 3988
the q will be fine with 1500, but i wouldnt rec. it. i would give it no more than 1200 clean.
Username: Basshead86
Try Google
Post Number: 8149
if you watch the gains, BB, listening habits and user aggression all have factors in this.
people have been putting 2000wRMS to Q's with no problem...it is all in the install/user
Username: Dustin3
Tigard, OR U.S.
Post Number: 3994
dam, 2k is alot. scott said he would give one over 1300 or so
Username: Fi_car_audio
Hades, NV
Post Number: 32
Id rather have a clean 1500W that a clipped out nasty 1000W amp on one ;)
But thats not to say that you should be running 1500W to one either... unless application and set up are spot on.
Username: Bernymac
AQ HD3!!, CA United States
Post Number: 800
Nice, we had two car audio gods respond in the same thread :D.
Username: Sb2012
Iowa US
Post Number: 429
WHOA:-)
im saving this one:-)
Username: Wolfman1966
WEST MONROE , LOUISIANA USA
Post Number: 835
FI-Q! No, Fi-q...no, go fi-q-rself...lol
