Silver Member Username: Kwrubel21Shelby Township, MI United States Post Number: 263 Registered: Dec-05 | does anyone know the specifics on the division of classes for competitions?? i have an ext. cab s10 and i plan on having four twelves with two amps. what other standards would determine what class i'm in?? |
Gold Member Username: SouthernrebelMonroe, Louisiana DD 9515d~~]... Post Number: 3682 Registered: Mar-04 | if you compete USACi and keep the box/amp/subs below the window line and behind the door jam....you will be in stock. What stock division depends on the amps. Most likly stock 601-1800w though w/ 2 amps. (unless the amps are rated at more than 900w each @ 4ohm) |
Silver Member Username: Kwrubel21Shelby Township, MI United States Post Number: 264 Registered: Dec-05 | if i do go above the window, does it even matter how many subs i have?? |
Silver Member Username: HockeyknightPost Number: 427 Registered: Apr-06 | hey sry to steal ur thread but iv been kinda wondering the same thing......i got a 92 caddy devile and i will soo have a 15" BTL with a orion 2500d........what could i compete at and can i run that orion at .5 for a burp???? |
Gold Member Username: SouthernrebelMonroe, Louisiana DD 9515d~~]... Post Number: 3686 Registered: Mar-04 | http://www.soundoff.org/06splrules.htm those are the USACi rules...they are in the process of changing the power classes, but all other rules will stand. Kevin, Usaci goes by your amps 4ohm power rating. (except in steet-beat) If you go over the window line, you will have to play in Modified. (ex, vehicles w/ walls...i am stuck in this class since i have a full size truck and took the back seat out...w/ a mini truck, you can play in stock if you stay below the window line) You must have all amps/sub/boxes behind the b-pillar (door jam)...or they will stick you in Super Mod Extreme. Adam, if your box is in the trunk, you will be in stock 601-1800. (unless you work at a shop or are sponsored...then you would be in Pro-stock 0-1000) |
Gold Member Username: SouthernrebelMonroe, Louisiana DD 9515d~~]... Post Number: 3687 Registered: Mar-04 | if you can keep your voltage above 11v...yes, that 2500d will take .5ohm DCR for burps. |
Gold Member Username: Troy81Tavernier, Fl Us Post Number: 1339 Registered: Mar-06 | where would my mustang with 2 12's on 8000 watts be? and a 500amp alt |
Gold Member Username: SouthernrebelMonroe, Louisiana DD 9515d~~]... Post Number: 3692 Registered: Mar-04 | whats the 4ohm rating on your amp(s)? how many amps do you have? how many batts? |
Silver Member Username: ShortysetniesRock Vegas, NC US Post Number: 424 Registered: Mar-06 | Here is a random question. Could you take the "guts out of a 2500 w amp and stick it in a 1500 w amp and get away with it? I hope that makes sense. Not trying to do it, just wondering |
Silver Member Username: Mr_keboAlbertville, Al USA Post Number: 708 Registered: Nov-04 | 500 amp alt who makes thats? I just sold my mustang and the largest i could get was a 300 amp alt. |
Gold Member Username: Troy81Tavernier, Fl Us Post Number: 1342 Registered: Mar-06 | well its one amp, the memphis 4000, running at .5 ohms, so its really like 7300, but still, so yah, ummm 1000rms prolly at 4 ohms since its 4 @ 1 ohm |
Gold Member Username: Troy81Tavernier, Fl Us Post Number: 1343 Registered: Mar-06 | Competitors whose systems include amplifiers that are not manufacturer rated, are modified internally, or not commercially available will be required to compete in the unlimited power class of their respective division. |
Gold Member Username: SouthernrebelMonroe, Louisiana DD 9515d~~]... Post Number: 3693 Registered: Mar-04 | Troy...you would be in stock 601-1800 if your box is the trunk. |
Gold Member Username: SouthernrebelMonroe, Louisiana DD 9515d~~]... Post Number: 3694 Registered: Mar-04 | BTW...w/ a strong electrical system, you may squeaze ~5000w out of that 4000d. (not 7000+) |
Gold Member Username: Troy81Tavernier, Fl Us Post Number: 1346 Registered: Mar-06 | marshall, you can get 7300+ out of it, very sick amp |
Gold Member Username: BestmankindFi AudioBTL Post Number: 6794 Registered: Oct-05 | marshall.....i was wondering, if i just enter the comp, would they direct me to the class i need to be in or do i have to decide for myself? |
Gold Member Username: SouthernrebelMonroe, Louisiana DD 9515d~~]... Post Number: 3695 Registered: Mar-04 | Troy, If you get a true 7300w out of that amp on a 14v system...dam. I have heard of a few people getting ~6200w out of them on an 18v system. Chad, Yes...they judge will put you in the correct class. You will just have to show him the install and tell him the amps. |
Silver Member Username: Kwrubel21Shelby Township, MI United States Post Number: 265 Registered: Dec-05 | hey marshall, i'm 99% positive i'll be going over the window line with my box. but my box will be behind the door jam. does this make any difference in what class i would be in? also, where can i find competitions in my area? |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 1487 Registered: Nov-05 | anything over the window line will stick you in pro.. i've known them to do 1/8th over and stick you to pro.. best bet is keep it under the window line.. |
Gold Member Username: SouthernrebelMonroe, Louisiana DD 9515d~~]... Post Number: 3703 Registered: Mar-04 | In USACi...even if you are 1/8" over the window line you will be in Modified. You have to pass the 'string test' to compete in stock or prostock. You can compete in Street-Beat if you are over the window line though. SB is 30sec average while playing music...not burps. here is a quick list of classes: http://www.soundoff.org/rules.htm http://www.soundoff.org/showschedule.aspx USACi shows. Also, check out: www.dbdrag.com their rules are different...i dont compete dBDrag, so i'm not sure on classes. The class according to sub # and size and amp#. |
Silver Member Username: Volfenhagking1600Atlanta, Georgia USA Post Number: 141 Registered: Oct-06 | how do you wire a sub at .5 ohms |
