01 Z71
Username: Mr_kebo
Albertville, Al USA
Post Number: 702
Well my buddy just bought an 01 GMC Z71. He is wanting to get as loud as possible and keep his rear seats. I found a box that holds 4 10" that goes under the seat. Anyone know of any good made boxes for his truck.
Username: Bernymac
AQ HD3!!, CA United States
Post Number: 793
he has a 3rd row seat correct? I don't think they make box's for 4 10's *refabs*. You know what everyone is going to say. "Build a box". So what subs does he plan to use?
Username: Southernrebel
Post Number: 3670
you only have 2cuft to work w/ under that back seat.
i have never seen a box for 4 10's that would fit under the seat of a GMC truck. even if you could sneak a box in there to fit 4...you would have too little airspace for them.
IMO, if you wanna keep the seat, either fiber-glass an enclosure...or just grab a nice prefab for 2 12's. (downfire)
you have VERY little space to work with.
Username: Mr_kebo
Albertville, Al USA
Post Number: 709
http://www.supercrewsound.com/shop/detail/11/192.htm he was gonna run 4 11Kv.2 with 1 eD NINE.1 amp. eD 6500 componets and 2 eU-700s with an eD NINe.4 amp.
Username: Mr_kebo
Albertville, Al USA
Post Number: 711
Gonna run those eD eU-700's in the rear doors. I wanna sound deadend the crap out of his doors. Im doing all this for him while he is in iraq.
Post Number: 3697
oh...you have a super-crew.
I was talking about an ext cab.
Username: Mr_kebo
Albertville, Al USA
Post Number: 712
http://pics.thebiglot.com/356653.jpg thats a truck just like his. I dont know what it is. he says extended cab but i just wanna make sure of what he has and what box i can get for him
Post Number: 3700
yep...thats an ext cab.
that box you posted wont fit in that truck.
go w/ 2 nice 12's and be done w/ it.
Username: Mr_kebo
Albertville, Al USA
Post Number: 713
Fits 99-06 Chevrolet Extended Cab Truck. Does not fit Crew Cabs.
Post Number: 3701
well...that is the first one i have seen that fits an ext cab w/ 4 10's.
but after displacment, you should have .58cuft per subs...that will do pretty well w/ 4 11kv.2's.
a word of caution though...when you get the box, go reglue EVERY seem just to be on the safe side...gorrilla glue and latex gloves are your friend.
Username: Mr_kebo
Albertville, Al USA
Post Number: 714
yea i had planed on regluing and coat the inside of it with resin for some strength.
Username: Bernymac
Post Number: 801
thats what I did, I resined the inside on every 90 degree corner. Learned it by seeing Steve Meade do it.
Username: Mr_kebo
Albertville, Al USA
Post Number: 715
yep :D
