SI Mag 15''
Username: Avirex64
Vallejo, CA United States
Post Number: 160
ok, my friend is looking to get 2 15's for his car, I told him about the mags and he doesnt believe me, I told him 1 15'' will slap hard enough but the still wants to get 2. Can someone please let him know that 1 15'' will be enough bass.
Username: Extrmndor3
Life is GOOD, Ill Us
Post Number: 2419
ull be good wiht a single mag but he will be better with a dd 9500 15 inch sub
Username: Basshead86
Try Google
Post Number: 8239
stock charging system????
and a Magnum is a VERY good choice.:-)
Username: Bernymac
AQ HD3!!, CA United States
Post Number: 808
Your friend has a lot of things to consider. If he plans to run over 1500+rms or even less (depends on cars stock alt and such) which IMO is the range where you need to start upgrading your charging system. So instead of getting two 15"s get 1, and then use the other money to upgrade your charging system. Would be nice to upgrade anyways. And then add another subwoofer and amp later. Thats my opionion, but it depends if he has the money or if he is going to do the charging system upgrades already. Show him some videos on www.realmofexcursion.com
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3223
if he doesn't wants to spend 500$ on a MAG, show him a FI Q, another option, not the same but still decent and cheap.
am i right muddy? lol!
Try Google
Post Number: 8243
