Alpine 450 VS Pioneer GM-D510M
Username: Chevyfan502
Post Number: 19
i want to push 2 DD2512's and im trying to find 2 good mono amps for a lower price that will last and sound good.....the alpine mrp-m450 puts out 400 rms (tested over 400 like 425 ive read) and the pioneer puts out 600rms (both at 2 ohms)....yea the pioneer puts out alot more, but how do they compare for sound quality and reliability? PLZ help....answer these questions plz and also any other suggestions of good amps for around the price of these 2(im an ebay shopper, kinda leanin toward only new though not used)....thanks
Username: Rovin
Trinidad & T...
Post Number: 9619
what da hell !? ^^^^
dude 1 of those subs can handle 1500wrms EACH so y r u looking @ such low powered amps
if those r dual 4ohms then look for 1 amp that does @ least 2000wrms @ 1ohm or better yet 2500wrms @ 1ohm.........
Username: Audioguy22
S.F., Cal.
Post Number: 308
I've heard the pie and its one of there(oops, we did something right)amps! its a killer little amp!
Post Number: 20
the dd2512a's are rated 500rms but yea i kno they can take much more, but still from 400-600 watt amps i'll be pushin at least 75 percent of the rms of the subs or more....
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3205
Trevor, at least get a soundstream PCA 1500d if they're dual 4 ohm
Post Number: 21
how much is that amp, where can i find it, and what is wrong with the pioneer, i just want to kno if it is a good sq amp that will hold up and put out a true, or at least close to 600rms, with 2 of those, one for each sub, it should push them pretty well since they are 500rms subs
Username: Juliob
Post Number: 3209
trevor, the soundstream is 1500w rms at 1 ohm. You can find it on ebay just write soundstream mono
