Channels
Username: Ote888
Philippines
could somebody help me what are the differences between 2 channels,4 channels amplifiers??
Username: Ctmike
Ct.
Post Number: 2208
2 channels are for a pair of speakers, 4 channels are for 4 speakers. generally you get a 2 channel amp if just amping your front (component usually) speakers and you get a 4 channel if amping both the front set and rear set of speakers in your car.
Username: Brynm
Prince Albert, SK Canada
Post Number: 221
most four channel amps let you have different settings for the front and rear allowing you to set it up for different size speakers, basically it's like having two seperate 2 channel amps in the same case.
Username: Ote888
Philippines
Post Number: 8
hey bryn thanks... i appreciate your answers.. thanks!
Username: Ote888
Philippines
Post Number: 9
hey ctmike.. thank you also for the answers.. help me a lot..thanks!
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3187
oscar, read this...
www.wickedcases.com
www.bcae1.com
you can learn some things there
