DMM meter
Username: Volfenhagking1600
Atlanta, Georgia USA
Post Number: 116
On my dmm meter for ac voltage it has it where you can switch to 600 and 200. Which one is right if i want to adjust my gains?
Username: Frkkevin
Post Number: 1478
Post Number: 118
thanks man...if i had 800wrms...how would you figure out how many volts to match it up with the cd player?
Username: Frkkevin
Post Number: 1479
800 rms @ 1 ohm = 28.28volts
800 rms @ 2 ohm = 40volts
Post Number: 128
yea i have the subs wired to 2 ohms, but is that 800wrms to both subs or is it 400w a peice
