SPL setup
Username: Hockeyknight
Post Number: 414
whats the loudest spl setup i could get fer under $1000
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 3143
just sub and amp for 1000? or what do you need?
Post Number: 415
sub and amp
Post Number: 416
oh and i want 1 15
Post Number: 417
and 1 last thing....ill have a 250a alt and i dont wanna get another batt if possible
Username: Ctmike
Ct.
Post Number: 2201
under $800
sub:
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16275
amp:
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16922
Post Number: 418
........... im not a big fan of kicker subs how bout a fi Q or a audioque hd3???? or anything else
Username: Stnorris
Davenport, IA US
Post Number: 1533
BTL 15 or 18, and an orion 2500d?
Username: Stnorris
Davenport, IA US
Post Number: 1534
you can get the btl 15 fully loaded for under $500, and maybe find a cheap orion 2500d for around 500 or under on ebay. sometimes theyre are some used ones on ebay, if you not against doing htat.
it would stomp on the L7 with the zx1000.
Username: Ctmike
Ct.
Post Number: 2203
i don't like solo's neither, but they are cheap spl. personally that kicker 1000.1 amp and a q would be a great setup.
Username: Sb2012
Iowa US
Post Number: 414
AQ HD3...
and a good 1500-2K watt amp...
maybe even look into Orion 2500D
Post Number: 419
with a 2500d would i need another batt though??????????????
Username: Bernymac
AQ HD3!!, CA United States
Post Number: 759
If you already have 1 good battery, optima anything along those lines you should be okay, but if its a regular car battery (lead acid) I would question it. Not sure.
Post Number: 422
so if i put in 1 good redtop up front id be fine???
Username: Bernymac
Post Number: 776
How about this, try out your alternator with the battery you have now for like the first 2 minutes or so, if you see electrical/charging problems, then get a kinetik 2400 if possible. If not, get a redtop batt. Kinetik will be like two redtops btw. But you can go with a lower model somewhere above the 1000-2000 model range and you should be fine, it'll be bigger than a red top thats forsure.
Post Number: 424
k but i might be fine with the stock batt?? well how much is a lower model kenetic??
Username: Bernymac
Post Number: 794
200-280, Look it up at www.woofersetc.com.
